what psu
16 Nov 2006
Intel i5 4460
SAPPHIRE AMD R9 280
Gigabyte Z97X-Gaming
Crucial CT256MX100SSD1
Currently trying to use Corsair HX 520W ATX2.2 Modular SLI Compliant PSU but the gfx card isn't been rcognised and have been told the psu is probably not good enough.
The whole system boots up fine with onboard gfx.
Quite willing to buy new cpu but obviously want the card to work.
What power connections does the 280 have? I think its 2 x 6 pin? Are both of these in place correctly.
The Corsair is fine for your setup and should work fine.
Does the HX not have x2 6 pin pcie or is one not an 8 pin that splits into 6 and 2. Iirc on some HX units the pcie cables are hardwired to the unit, and some are modular.
I used the cables I had, it may have come with more but I probably lost them. Would taking the power off a molar be a problem?
