- 27 Apr 2018
Hey everyone, just in the process of finishing up my loop.
My current pump specs are as follows: (XSPC x4 Photon)
Heat Killer IV CPU Block (7600k)
Heat Killer IV GPU Block (1080TI)
3 x XSPC TX (Ultra Thin) 480mm Radiator
1 x XSPC TX (Ultra Thin) 360mm Radiator
XSPC Photon 270 Resevoir
XSPC x4 Pump
4 x Koolance Quick Disconnects QD3
11/16 Soft Tubing
I am assuming I will need a second pump for all this, but I am unsure which one. I see people always recommending the "D5", but I can only see a screw ring version on OCUK? What exactly am I meant to screw it in to?
Thanks!
- Maximum Flow: 600 lph (12V)
- Maximum Head Delivery: 3m (12V)
XSPC x4 Pump
11/16 Soft Tubing
Thanks!
