what RAM for 4CoreDual-SATA2 + Q6600 ?
Permabanned
18 May 2006
thanks,
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
board only goes to 667Mhz, and that is 800Mhz ?
so I take it that makes no difference if it was set to run at 553Mhz ?
used that ram in that MB but with a e6300, it ran without a problem, once i flashed the bios as the one it came with didn't support the 2400pro GPU i had
Thanks Vonny,
I got the OCZ like you suggested, works fine :-)
detects at 533 which I wanted. (although I'd have thought it would pick 667 being higher ?)
but sods law, I've now killed my graphics card (see new post in Graphics section)
so benchmarks will have to wait a while
not my day really.
