- 18 Sep 2011
Hi I have just bought a m17xr3 (will arrive withing 10 days !! so slow) and would like to know the best cost effective memory upgrade
It comes with 2x2gb and has 4 dimm slots. I was thinking of adding just 1x4gb to a spare slot to make it 8gb, is it ok to have 2,2,4,0 in the slots? I read something about them needing to be the same for the ram to be in dual channel mode, is that true? The other thing is I see there are 2 easy to get top slots and 2 requiring the keyboard to be removed. If it turns out the easy to reach ones are filled with the 2x2 I was thinking of just replacing one with a 4gb making it 6 overall. Is that a good idea?
Thanks
Specs for laptop below if that helps
Alienware M17xR3 : Nebula Red
Blu-ray Disc (BD) Combo (Reads BD and Writes to DVD/CD)
Wireless: Dell 375 Bluetooth Card
320 GB SATA Hard Drive (7200 RPM)
Carry Case : Not Included
Genuine Windows 7 Home Premium (64 BIT)
Graphics: 2 GB GDDR5 AMD Radeon HD 6970M w/ PowerXpress
Misc
Display: 17.3 inch WideHD+ (1600 x 900) WLED LCD
Battery : Primary 9-cell 90W/HR LI-ION
Processor: Intel Core i7-2630QM (2.00GHz, 6MB cache, Quad Core) with Turbo Boost 2.0 up to 2.80 GHz
4 GB Dual Channel DDR3 SDRAM at 1333MHz (2 DIMMs)
Back Up Media Not Included
Adobe Acrobat 9.0 Reader
Misc
Wireless : Dell Wireless 1501 wireless-N
Certified Refurbished
Thanks
Misc
Misc
