What RAM would be best to go with
10 Jan 2014
Hi,I've just started a new Build. I've just bought a Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor to go with My Asus Rampage Black Edition.
What would be a good Ram kit to go with the board and processor ??
I have a budget of about £200-300 for the Memory
Many Thanks in Advance ;-)
P.S. I'm a newbie when it comes to Overclocking so I would like something that will run fast straight off the bat till I gets My head around Overclocking.
All ram usually run straight off the bat until you set the overcclock profile in the motherboard bios, They will just down clock .
Here are the fastest ram that is on the compatible list for your motherboard.
YOUR BASKET
1 x Kingston HyperX Beast 32GB (4x8GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/32X) £299.99
1 x Kingston HyperX Beast 16GB (4x4GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/16X) £161.99
Cheers, I will Probably get a set of the 32GB ;)
