- 23 Aug 2006
- North Wales
Hi what registry cleaner would you recommend for windows 8
Thanks
Thanks
This is the general consensus. No performance boost and quite a lot of horror stories.None, they're snake oil at best and system damaging at worst. I've never seen a noticeable improvement having run one on a system.
yeh do these even work
The problem is that sometimes the cleaners can be a bit overzealous and delete important entries which can result in software not working or even a non-booting OS.
