What Res for a 28"
10 Nov 2006
Lincolnshire
I have a 28" HD LCD Phillips TV I use for my 360 I want to use it with my PC as well. I have a 8800GTX, firstly what res options will I be able to run it at when I plugg in the TV and becourse my GPU has 2 DVI ports in the back can I have both in at the same time and only use one at a time?
The TV will probably only support 1366 x 768.
If you have the TV and the monitor plugged in you can set it up to have an extended desktop (each with their own independent resolution), or you can have them both showing the same image, or one or the other. It's up to you.
