Disclaimer: We really unsure where to put this, it could go in GPU/Monitor/PC Game section
Feel free to move it, but i think the GPU section Is a good place to start for good conversation
I want to give my Experience on What I feel is best Monitor Resolution for Gaming & how to best pick the right one for you.
So the question remains what resolution is best for me?
What experience do i have?
i have had almost every Resolution/refresh rate/Screen type Combo their is, Currently have 10+ monitors in my collection which i often swap around with. These includes Gsync/Freesync & no Sync.
Few monitors i own & use for various reasons:
1080p:
SA27950D - 1080p 120hz VA
Acer Predator - 27" 1080p 240hz TN
Dell 2913WM 1080p ultrawide VA
1440p
PG278Q - 1440p 144hz TN
PG279QE 1440p 165hz IPS
Acer X34A - 1440p Ultra wide 100hz IPS
4K
PG278AQ - 4K 60hz IPS
LG CX 48 - 4k 120hz OLED
1080p:
1440p
4K
1080p / 1080p High refresh rate
This monitor resolution i define as the "just Works" resolution, you can pick up most Graphics cards & computers & have a good experience out of the box. This is where Casual People should normally sit
Benefits
- Low Graphic card requirements
- Cheaper than other resolutions
- Extreme High refresh rate is truly the best experience for Real Competitive esports ("professionals")
Drawbacks- Need a Fast CPU if you want to go for 144HZ+
- Less Visual Quality compared to 1440p+
How hard is it to go back from 1440+ to 1080P?
1080p feels bury after going to 1440p & can take many days or weeks to get over the feeling that your missing clarity
Possible Use case:- Don't want to upgrade your PC every 1-3 years
- Low on Budget
- want high refresh rate for low resources.
- play esports only
Card to Suggest:- Nvidia xx6x
- AMD x6x or x7xx
1440p / 1440p High refresh rate
- This monitor resolution i define as the "Works with Eye candy" resolution, you can pick up most Graphics cards & computers & have a good experience out of the box. This is where people sit who wants Both Eye candy & refresh rate.
Benefits
- High refresh rate gives good FPS experience
- less requirement on the CPU
- better visuals over 1080p
- Less Visual Quality compared to 4K+
- more expensive
How hard is it to go back from 4K to 1440p ?
1440p feels bury after going to 4K & can take many days or weeks to get over the feeling that your missing clarity
Possible Use case:- Don't want to upgrade your PC every 1-2 years
- want both eye candy and high refresh rate
- want high refresh rate and dont mind spending £300+ on GPU
- Card to Suggest:
- Nvidia xx6x
- AMD x7x or x7xx
1440p / 1440p Ultra wide / High refresh rate
- This monitor resolution i define as the "Tweaker" resolution, you need to pick up a high end Graphics cards to have a good experience out of the box. This is for tweakers as most games have issues with ULtrawide, & you may want to edit .ini files or configs to get older games to run correctly.
Benefits
- better visuals over 1440p
- Ultrawide experience is great
Drawbacks- Less Visual Quality compared to 4K+
- more expensive
- need to tweak many games to get a good experience
How hard is it to go back from 4K to 1440p UW ?
its fine to be honest.
Possible Use case:- happy to upgrade often for good eye candy
- Don't mind spending £500+ on GPU
- Card to Suggest:
- Nvidia xx7x
- AMD x8x or x8xx
4K / High REfresh rate 4K!
This monitor resolution i define as the "Want everything & eat it" resolution, you need to pick up a very high end Graphics cards to have a good experience out of the box. This is where you want the best of the best.
Benefits
- almost NO requirement on the CPU
- HIgh Visual qaulity
- expensive, Expensive Expensive
- need to tweak many games to get a good experience with good frame rate
Possible Use case:- you play story games/ single player most/ you can sit back from your screen
- want all the eye candy
- Don't mind spending £600+ on GPU
- Card to Suggest:
- Nvidia x8x
- AMD x8x or x8xx
