Kind of a longish post sorry
Maybe some of you well informed fellow members can offer me some advice on this one
I bought a multi gym (Weider Pro 8700) from Littlewoods, this is the item: http://www.littlewoods.com/weider-pro-8700-multigym/928367614.prd?_requestid=157793
Anyway whilst assembling it I got so far through the assembly instructions and got to a part where the arm (butterfly, bench press etc) required putting two pins in that have a rubber strip, as shown below:
The picture above doesn't make it look so bad, but its the first time I have seen this type of thing and aside from not liking it (the design is awful as you constantly need to move the pins around depending on butterfly or press exercise) , the pins are just not user friendly at all (quite hard to remove and slide back in).
I contacted them by live chat and explained that I needed to return it as the design and quality on this particular bit is poor but they refuse to allow me to return it.
Where do I stand with this? What are my options? 70% of the gym is still factory sealed, I have only assembled maybe 15%-25% and all was going well until I got to this point. The design just seems flimsy and not easy to use, I told them the product is poor but they wont listen.
I can either finish assembling it, hope the pins get easier to use over time and just get used to constantly moving the pins and hope it all works out ok or I can try and push for a return/exchange something else.
I have gotten the address to write to head office should I want to but not exactly sure yet. I asked if I could return and exchange for a different gym but they also refused this.
Before this I had a Marcy MWM 1100 which I got from the bay and it was brilliant and easy to use, but as I moved house not so long ago I decided to just get rid of it as it was few years old and just recently decided to get myself a new one which I hoped was better, but some aspects of this one don't seem as ergonomic or user friendly.
Do I have any rights to return this given the information above. Maybe I am just over reacting a little I don't know, it's been a stressful weekend, I should probably just finish building it and get used to it but I was quite annoyed when Littlewoods flat out refused to return it hence I wanted to know if I had any rights as a consumer to make them return should I go down that route? As I say some parts just don't look and feel right
Thanks
Thanks
