What router do I need for plusnet with my ac-lr. Also extending tv aerial on homeplug?
18 May 2006
The plusnet bundled router seems less stable than the BT one I have come off (even though they look the same!)
I thought ubiquiti did one (edge router) but it looks like they only have ethernet ports in and not the telephone small port that i'd expected to see. (im only on fibre to the cabinet).
Any suggestions on what I've missed please?
Also is it possible to extend a tv aerial connection via a hdmi cable or similar that I can pop into a homeplug and convert back at the other end?
Just use your BT router. If it fails to get PPPoE then it allows you to change the username, pop your plusnet one in and you're good to go.
You can't extend a TV aerial via powerline, 2 completely different mediums.
