What sandpaper
I got an Rotacraft dunno if it will be any good tho, only one way to find out. I got red primer, honda red, project pack and rubbing compound. Will red primer be okai on a small amount of plastic? :/
400 grit will do the job mate you dont need anything else. :)
Dont use red primer as it will bleed through the topcoat(uless its red ) use white/grey plastic primer.
Yeah the topcoat is red :) Thats what they guy in halfords said. :D I don't want to make a Project Log so I will post pics when I get it done further down the line
Red Primer and Honda Red :] I was going to go Volvo Red asin:
But they didn't stock it.
