I am thinking of buying a Sat Nav system for in my convertable, and have been looking at the TomTom Go 300 and a Medion PNA300, but cant decide between the two. The PNA300 is about £20 cheaper and has a 5" screen, but I cant find any reviews on it. Has anyone tried one out, if so what are your thoughts?
Can anyone recommend a decent system for about £300 that is better than the TomTom Go 300 or PNA 300? I dont need a PDA and want a system that gives voice directions, 2D map, post codes, and is simple to use.
Its a pity I cant find anymore out about The Medion unit as it was quite decent looking. I can only find the spec's on the Medion site and nobody seems to have reviewed it.
