what are the best setting to use at a wedding ac etc? and wht is the best lens out of the 3 i hve thanks guys
canon20d
50mm 1.8
70-200f4l
28-300 tamron
Canon Speedlite 580EX
If you're the main one you'll want another body, and have the 70-200 on one, and a 24-70 on another Well, that's what i'd do. Oh and use the 580ex obviously
If you're just a guest, then it depends on what you want to shoot, the location, and the light/space that location gives. If you have a bit of light and want to get a few candids, then the 70-200 might be a good one. Otherwise you'll be needing something wide, hence the 24-70 suggestion.
