Hi all,
what setting is best.
i have OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (OCZ3G1600LV6GK)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-129-OC
i have oced to 4.2 gig but have been having problems with the ram running @ 1600Mhz, have only been able to run ITB stable on 5 to 10 passes with ram running @1200Mhz also all games and progs are running fine no BSOD for over 2 weeks .
7-7-7-19 on 1.5v 6x is what i have had it set, to tried upping volts and to 8x but fail onIBT within 2 passes.
so today i seen on OCZ forums if i up my TRC to 45 and TRFC to 90 with command to 2 it should work 8-8-8-24 on 1.64v
It has just done 5 passes on IBT will do more testing l8r, but want to know is those settings ok upping the trc and trfc etc.
Hope it makes sense
thank you all in advance for any advice
Hope it makes sense
