Hi guys, im looking for a new motherboard but dont know which one to pick. Here are my specs currently.
Antec 1200 case
700 watt coolermaster M700 Psu
Nvidia 295 GTX Gpu
E8400 Wolfdale dual cpu overclocked at 3.9ghz
Arctic cooling freezer extreme cooler
8gig ddr2 1066 ram
Asus P5Q motherboard ( 1 Gpu slot only ) obviously still runs sli from that single slot but this is why i want to upgrade.
What would you guys upgrade if you had this system? i play game on the highest settings, always max things out at 1920 x 1080 on my viewsonic 23inch full hd monitor. Which motherboard would be recommended? or shall i just change the graphics card or ram? I run vista 64 bit and windows 7 64 bit if that helps. Any advice would be great thanks.
Antec 1200 case
Nvidia 295 GTX Gpu
8gig ddr2 1066 ram
