- 20 Apr 2011
- Stoke on Trent
I would be grateful for some opinions on an Asus 4850 (as i can find little info in the forums for the 4850, maybe it is tooooooo old
I have set the core to 750MHz and the Memory to 2260/1130 with Asus Smart Doctor. I am assuming this is a safe overclock as i have not increased any voltage.
Seems to cope fine at this OC with Heaven Benchmark and reached a temp of 63-65 and holding after 30 mins.
I am wondering if:
Any recommended safe settings are welcomed.
Thanks
)I have set the core to 750MHz and the Memory to 2260/1130 with Asus Smart Doctor. I am assuming this is a safe overclock as i have not increased any voltage.
I am wondering if:
- Is this a safe OC and temps for a 4850?
- Should i be able to get it higher then this? (average for a 4850), and would i benefit from higher?
- MSI Afterburner will not let me change the voltage (even after enabled in settings). Would i benefit from increasing the voltage to enable a higher OC? or is it even possible with this card?
Thanks
