What should be my next upgrade ?
Hi, 2013. Your spec is okay. If you just want a quick boost to gaming, I'd simply drop in a better GPU, and be done with it. For anything else, as stulid asked, please provide more details.
New hardware is on the horizon, so I wouldn't necessarily rush towards a major rebuild just yet.
More GFX power.
Its hard to say change the CPU when its running along at 4.5GHz.
Given the gutter-grade IPC of piledriver chips and the terrible SLI/CFX performance of AMD (AMD always shows off their multi GPU setups running on Intel platforms at trade shows :p:rolleyes:).... there is actually some compelling reason behind changing up that CPU at some point. Also, No DDR4, no PCIE3, No USB type C no USB 3.1 no M.2, no IRST, runs hotter than an afterburner on an F16, etc etc.
If you are a keen on staying with amd and have a realistic budget then I would wait for a mid-tier polaris card and possibly the zen architecture. dropping in another 8gb of ram would be a nice boost but if you are likely to upgrade then you will be needing to invest in ddr4
