What should I do with my Rig!?
25 Sep 2011
Evening,
I've recently moved back into my mothers place and have no where to use my rig so wondering what you would do with it personally as currently and likely for at least the next 6 months, sat in a cupboard.
Intel i7 2600K
Asus Maximus IV Extreme-Z MB
Corsair 16GB Vengeance Ram
2 x Asus GTX 580's
120GB Corsair SSD
1TB WD Black
1000W Corsair PSU
H80 Corsair CPU Water Cooler
NZXT Phantom White case
Options I can think of:
1. Break and sell it. In which case, what money am I looking at?
2. Pull GFX card and bits and put them in my work machine and bitcoin mine with them? thoughts?
3. Keep it in the cupboard.
I think best bet is to sell it, if your going to mine with it then I would try get AMD cards, your current cards would give you 2x 146 hash rate compared to a 7950 which gives 500-600 hash rate.
Also if it isn't getting use then it just losing you money I guess.
What are your problems with it - too slow, bored of the current config, want something new? What's up with it? :D
Ah derp, didn't read that, sorry. Yeah, I'd go ahead and sell it, you could get a decent amount of a good rig like that.
Sell it I would.
Maybe try and sell it as a complete item first and then possibly as components if that doesn't work?
