What should I upgrade on my PC?
Permabanned
26 Jul 2007
Coventry
Specs are as follows,
Q6600 G0 @ 3 GHz
8800GTX
4GB DDR2 PC5300
Gigabyte P35C-DS3R
Corsair HX520
22" TFT 1680x1050
I was thinking of getting a new graphics card to help with future games etc, but I can't see any games I won't be able to play fine on my current one except GT4. But I was wondering if my CPU is still considered any good?
Personally I think your CPU is fine, its your GPU which is probably the weakest link in that chain. If you up your GFX though, you might also need to look at a new PSU.
280gtx now they are sub £200!
you will undoubtedly need a better gfx card to play the new total war on max settings as those 20,000 people battles get very intense!
The CPU is fine, most progs don't even utilise 4 cores yet :)
