- 2 Aug 2006
- Liverpool
hi im thinking of getting some new parts for xmas and was wondering what to upgrade/add
my spec is in my sig
get a raptor if you can affordgames and internet browsing
dont think i'll get one seem too dearget a raptor if you can afford
i was thinkin of a new cpu will it make much difference im happy with my gpu it seems capable of still playing my games, what about a new heatsink my cpu seems to be running on the warm sideif its games also considered a cpu and gpu upgrade or are you waiting for corei7 and the next generation of gpus
more ram up to 4GB minimum
then tell use the rest of your budget or what you will likely be able to get
i am just toying with the ideaChristmas? If you are fine with what you have now then just wait and see![]()
i think rams a definite upgradeI went from 2GB to 4GB RAM and it actually LOWERED my 3DMark score. But In overall PC performance it made a lot of difference.
Seen as RAM is so cheap, its silly not to.
