What should i use to moniter Temps in vista 64 bit?
28 Oct 2006
Cambs/Florida
Hey all i am using vista 64 bit i had a bit off a tidy up in my case and removed one off the hds bays and it seems to be ice cold now...
What can i use to moniter my temps.. This is what speedfan says at idle..
best one for vista thats accurate is Core Temp, you need to set in the files properties to run as admin or the driver it uses wont work
I can't seem to get coretemp going its saying driver error....
Does it show a correct temp though?
I am getting 17/18c in speedfan and everest...
hopefully.. They are both the same.. I might pop on vmware and then install xp to that and try TAT.. so does TAT not work at all with 64 bit?
Lol figure this out... 0.94 coretemp is the same as speedfan 0.95 is the same as TAT..
