What size hole saw do you suggest using for 140mm fans?
Don't forget though, it's the frame that's measured, not the fan.
If you get a 134mm holesaw, you've got 3mm around the edges to play with, that should be plenty and roughly around the same size as the fan itself not including the fan frame.
