what size hose do i need?
28 Aug 2013
hi,
just putting my watercooler together cant fing any hose that will fit my pump seems it is too small wondering what to do is there any way round this my sizes are as follows cant see any suitable hose in overclockers
cheers
cpu block 10.5mm overal diamiter
pump 9.mm overall diamiter
Do you know the model at least or the type of fitting? :) I'm assuming it's a barb?
As for your cpu block, the fittings aren't integrated are they? They're separate barbs/compressions, right?
hi there yes they are both bard, the cpu block the fittings are seperate barb/compressions / screw into the block.
sorry there isnt a model number on it its a second hand one
Could you post a pic of the pump?
I'd like to say just get 13/10mm tubing (and 13/10 barbs/comps on the cpu block) and tighten the hell out of a clamp on there, but that's probably not the best idea :D
ED: Hang on, that 9.2mm.. Is that measured at the very end of the nozzle or at the widest point of the barb's 'arrowhead'?
