What size monitor?
8 Nov 2002
Parson Drove near Wisbech
As title I am using a 19 inch wide screen res 1440x900,
I would lke a hd screen with freeview built in and to mount on the wall rather than a stand, also I think it would need to go from graphics which is 8800gts with 2x dvi output,
How would I connect to the new screen as I am told they do not have the dvi on the larger ones, so size and how do I connect please.
Thanks for any help.
Wayne..
size would depend on the amount you want to spend and what you want..but can be anything over 23" (smallest HD freeview monitor i've seen is the Samsung on OCUK)..
dvi->HDMI connection isnt a problem, adapters arent hard to come by..
EDIT: Of course, you wont get sound from the dvi connections on an 8800, so assuming you're happy to keep your current sound setup then you'll be sorted
I was not sure what the other round connector is, I thought that would connect via hdmi and have sound put me right if I am wrong also would like 37 inch screen.Thank you for your advice and help..
Edit: forget what I said, I am being thick its the vid in and out port,
so all I would need is a dvi to hdmi cable, will try OcUK and see what they have...
someone on the forums might have a dvi-hdmi dongle they dont need going spare that you can nick..if you have no luck with that search..
