what size psu to go with?
19 Oct 2002
Yeovil
Im in the process of building a parvum system ,i5 4690k ,msi r290 ,1 ssd ,pump res combo , 4-6 fans and was unsure what size psu to go with it, Ive always like corsair brand wise ,currently have hx750 in my rig im using now ...what do you recommend ? was going to order this weekend
cheers in advance Q
I would say either an EVGA or Superflower 750w,850w or the Corsair AX 860, although I don't know if there are restrictions in the Parvum for PSU length???, if so the Superflowers are the biggest at 200mm.
Plenty of headroom with any of those.
I have flat cables on my Seasonic and I like them but a lot of people hate them.
The Corsair is more expensive than the two units I suggested above and not as good in my opinion. There were also problems with the RM series fans not spinning up when they should have. Not sure if they have fixed that or not. If it fails you have to return it to Holland which costs £20-25. If you went with the Superflower the warranty is with OCUK for the life of the psu.
