What size widescreen monitor do I need . . .
4 Aug 2006
To give the same vertical size as my current 21 inch 4:3 CRT?? So basically I just want the same height, but wider :)
If it helps I've measured the vertical distance of visible screen and it's approx 11.75 inches.
fwiw, dual screening with lcd and crt is not a good mix, the difference in picture is annoying and you will start to become irritated by the crt flicker.
Thanks for the tip, though I had no intention of doing this :) I just wanted to make sure when I upgrade that I don't go smaller vertically, just that I keep the same size (or bigger!) and wider.
