AMD processors based on the Phenom and Phenom II (Athlon II, Sempron II, Turion II, etc.) only have a single thermal sensor. Thus Core Temp will only display a single CPU temperature reading. There is no way of getting a per-core reading on these processors.
Starting with the Phenoms, AMD's digital sensor no longer reports an absolute temperature value anymore, but a reading with a certain offset, which is unknown. It is estimated that this offset is between 10 - 15c.
It gets debated a lot, but I'm pretty sure with the AMD Phenom IIs (the X6's at least) you don't read core temps you read CPU temp.
HWMonitor will display this, but it varies from motherboard to motherboard as to what it calls it. On my Gigabyte boards it was TMPIN1, but it may even vary by model.
Both CoreTemp and HW monitor show the same tempreatures the same, 15 degrees at idle. Is there anyway to accurately measure the tempreature?
You can't really do that, as Core Temp kind of began to equalize out to give a normalish temperature.
And each CPU is different, some are only off a few C.
Yea, TMPIN1 on my HW Monitor gives me my temps![]()
Up untill I saw this post I beleived CPU Socket temp was the one to watch.
Very good post that, I recommend a thorough read of it plus the links within it.
My Athlon x4 says its running at 15-17c idle on core temp with an arctic freezer 7 on top of it......
