What spec for htpc?
just a little over £500
also if you can get another small hdd for the OS and apps so you can have the 500 for movies, music, PVR etc.
strange that i can see it, oh well
Antec Fusion HTPC Case - 430HE Watt PSU £95.99
(£112.79) £95.99
(£112.79)
Seagate Barracuda 7200.9 500GB ST3500641AS SATA-II 16MB Cache - OEM £68.99
(£81.06) £68.99
(£81.06)
Liteon DVD-8900 16x DVD±RW/RAM (Black) - OEM £13.99
(£16.44) £13.99
(£16.44)
Abit Fatal1ty F-I90HD ATI Micro ATX (Socket 775) PCI-Express DDR2 Motherboard £69.99
(£82.24) £69.99
(£82.24)
GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX21GB5300DC) £42.99
(£50.51) £42.99
(£50.51)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £101.99
(£119.84) £101.99
(£119.84)
Hauppauge WinTV HVR-1100 Freeview TV Tuner £34.99
(£41.11) £34.99
(£41.11)
Sub Total : £428.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.95
Vat : £76.80
Total : £515.68
I couldnt see the grab either!
I'm also looking to build a HTPC and the spec youve shown is almost identical to the one I am looking at.
Same case, MB, Ram (albeit 2GB). Ive chosen the Spinpoint 500GB (x2) and a E6600 as its cheaper this week!
So the onboard graphics of this case really will decode well HD?
OK - Obviously as its going to be used for cinema stuff, I want it as quite as possible. Ive read that I could use the supplied cooler that comes with the CPU - but think it probably better to get a beefier option thats probably going to be much quiter also. What would you recommend (baring in mind the case.)
Just wished the MB had another PCI slot. I was looking to use a Satellite and Freeview card. (Yes I know you can get a 4 in one card - but its single tuner only)
