What speed could i get max.
Permabanned
10 Aug 2006
Scotland
Im currently on 2.5mb ADSL MAX!
DSL Status: UP
DSL Modulation Mode: GDMT
DSL Path Mode: INTERLEAVED
Downstream Rate: 2560 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 4 db
Upstream Margin: 10 db
Downstream Line Attenuation: 61
Upstream Line Attenuation: 31
Downstream Transmit Power: 0
Upstream Transmit Power: 0
PVC Connection
Connection:
Encapsulation: RFC 2364 PPPoA
Multiplexing: LLC
Qos: UBR
Pcr Rate: 0
Scr Rate: 0
Autodetect: Disable
VPI: 0
VCI: 38
Enable: Yes
PVC Status: Applied
Well i download at 240kbps per second but realy wanting a faster speed just wondering if i applied for a bt package would i get higher is that the most i would get.
You're not going to get any more than you've already got, whatever you do (barring getting cable of course).
Ol!ver said:
Wouldnt it be the 2mb BRAS profile at those sync speeds?
Yup. I wasn't referring to the BRAS profile though.
Sorry, whe someone asks about what speed they're going to get I assume they want to know how fast they'll download stuff.
On LLU, that would be 2.5Mbps - "What speed could i get max.".
That's cool, I was under the impression that ADSL MAX meant it wasn't LLU though. Are they not two seperate systems?
Cheers
Yup. But I didn't say they were all one?
The OP asked what the max they were going to get was. That's 2.5Mbps.
I think we're talking at cross-purposes. I mean he said he was on MAX and wanted to know how fast he was going to get data down the pipe at that sync, which is 2mb. Maybe I mis-understood the question.
Either way, question answered (twice :D ) so job done.
I think the point is, he didn't ask that - just what the max he was going to get is - but either way, some question's been answered. :shrug:
You are being pedantic for some reason ;) The OP obviously wanted to know the actual data rate he would be getting - in this case 2Mb - as anything else is meaningless.
Is it just me, or do you ask this question every other week? :p
As has been said before, unless you move you're not going to get anything more than that.
