- 25 Jun 2006
hey all,
recently upgraded my pc and in the upgrade i purchased the below ram.
16GB corsair ddr3 pc317066 (2133mhz) CAS 11-11-11-27 1.5v
Now my other specs are i5-2500k, gtx 980, z77 mobo.
It's currently set at 1333mhz with the default 9-9-9-24 settings, should i leave it at that or would i benefit from setting the actual rated ram speed/cas settings?? I read in a few places that anything over 1600mhz on the 2500k would be pointless?? If I should set it at 1600 then what settings should i put it at??
Oooorr, should I just enable XMP and be done with it??
Thanks in advance!
edit: machine will be used for gaming
Thanks in advance!
