what steering wheel set for under £200?
17 Jan 2016
isle of wight
I have decided that I really want to get a wheel to add to my driving experience on pc,problem is ive never owned a wheel before and know little about them,could I have some thoughts on what you consider to be a half decent wheel setup for under £200?
thanks
think I'm going to go with the thrustmaster force feedback wheel as its not a bad price and seems ok :)
its ok,ive done a little google search and it seems a great wheel setup,thanks a lot for the comment,think I will get one as seems better than the thrustmaster :)
thanks again
yes thanks,i will go with the G29 when I have the cash,just bought a mechanical keyboard with cherry browns so bit skint again now but defo going for the G29
thanks again
