What Team Group 8Pack kit to get ??
16 Jun 2010
Manchester
Ryzen cant run 4K and very very few can run 3600mhz either.
For me buy the 4K at that price and run it at 3200mhz C14. Then when CPUs capable of running such speeds come out you have the best ram to cope with the speed bump.
That was my thinking too, i just didnt know if the 4k kit would run the 3200mhz @ c14.
Anyway thanks for the reply and have ordered the 4k kit :)
With 3200 kit you can set XMP, with 4000 Kit it's manual, do you just set to XMP then set all the primary timings/ignore secondary?
@xtremedetailz
but if you have any clearance issues with air cooler or AIO at top with some case then 3200 Dark kit will help - specially as you can decrease the height
Yeah brilliant, thanks guys, i have fitted my xtreem versions as i have no issues with clearance.
Still not clocked them yet tho...Think they are running at 2133mhz
