What temps are what?
6 Nov 2004
Temp1 - Northbridge?
Temp2 - CPU (i'm 100% sure on that)
Temp3 - Havent a clue, what runs at 15C lol
HD0 - Hard drive
HD1 - Hard drive
Temp1 - Case temp?
I also have a "Core" temp which I disabled, simply because its irratic and its hard to control the automatic fan that way.
But i'm still a bit worried about that temp, goes high easily when under load - does that mean my heatsink is not covering the second core? Because when I stress test first core - Temp2 moves up slowly, when I stress test core2 - Core temp goes crazy high.
Hi there,
You need to grab the correct config. for your motherboard.
HERE is the link to the page, you will need to register to access it.
Trill
I tried loads of them configs, what exactly do they do? small changes dont change the name of the things.
EDIT: Sorry this one guy did, how can my chipset be at 16c? whats ACPI and Chassis temps?
