What the diff between these 2 Lianli cases?
3 Apr 2007
South of the Watford Gap!
The pc 60fw has 5 x 3.5" bays as opposed to 4 in the pc60fnwb, both are bare aluminium internally, also the pc 60 fnwb has cable tidying holes pre cut in the mobo tray.
So the 60FNWB might be a newer case as it has cutouts for mounting the HSF without the need to remove the mobo and a cutout/filter on the bottom for the PSU to draw air from.
The newer PC-60FNW also has eight expansion card slots opposed to the seven of the PC-60FW. The PC-60FNW has a windowed side panel as the pictures show (the letter 'W' in the name relates to this). There is a none windowed version available, not surprisingly that's called the PC-60FN.
