What the difference between a titan & GTX 780 ??
Caporegime
27 Nov 2005
Guernsey
Can anyone tell me what the difference is between the titan & GTX 780 hardware please ??
MSI TITAN Specification:-
- GPU: GeForce GTX TITAN
- Core Base Clock: 837 MHz
- Core Boost Clock: 876 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
MSI GTX 780 Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Size: 3072MB GDDR5
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Is the only hardware difference between them more memory & more CUDA Cores (((whatever CUDA Cores are :confused: :o ))) ??
about £300 :D
6GB on the Titan and 3GB on the 780.
If you are a triple screen or 4K gamer, the Titan has plenty of extra VRAM. You would still need a couple of them though to push the power needed to make some of the modern AAA games playable.
780 = wife "you can take me to dinner and get me a new pair of shoes if your getting that"
Titan = wife "you can take me to dinner and get me a new pair of shoes if your getting that and where are we going on holiday"
Otherwise what gregster said :D
Edit: got mine today, off for dinner about 7, off on holiday to crete thursday, force is strong with this one :(
Were you the lucky winner of that lightning for £420?
Brilliant buy considering I paid that for a Gigabyte one just over a month ago, still a great clocker though so can't complain.
Cost me a new bathroom :(
Yep i was, :D quick bios flash and it runs at 1355MHz now i need a waterblock, c'mon EK pull ya finger out ;)
