What the fastest GPU card that will fit in a Antec Fusion HTPC Case ??
Caporegime
27 Nov 2005
Guernsey
Come on guys what the fastest GPU card i can buy that will fit into a Antec Fusion HTPC case ???
Don't care if it's ATI or nvidia...
I'll get the ball rolling. I've got a HIS radeon 4670 with stock cooler in mine. Tight fit though. Think theres no more than 2 or 3 centimeters between the top of it and the case cover. I'd hate to try and get some of the bigger nVidia cards in there.
Thanks for the replys so far...
But Sorry guys but these cards are not going be fast enough........I need something faster that can game at 1080p on my plasma......
I have an 8800GT in mine at the mo, but you should be able to fit a 4890 in. From what I can remember they're 9 and a half inches which is just enough clearance, if all else fails get the dremel out
:D
