Enfield said:An example of a misfire is when a car is running on 3 cyclinders instead of 4 and it sounds and feels like crap.
TinkerBell said:How can you tell its not running on all cyclinders? apart from it feeling and sounding crap!
Enfield said:Well if you can't hear it, you're blatently deaf and if you can't feel it then well you're a vegetable![]()
) and you will notice a lack of power, more vibration and dire fuel economy. Depending on the cause it may only misfire under certain conditions, e.g. usualy under load if it's ignition related.
siztenboots said:Test each spark plug by disconnecting one lead and see if that make is worse ( in which case that cylinder was doing useful work ) or no change ( so that cylinder is waste )
Mind the voltage !
yes is does.Dogbreath said:That trick doesn't work if the engine uses a wasted spark ignition system!
Usher said:If your car is petrol & it sounds like diesel then thats it![]()
M0T said:My car is petrol and sounds like a diesel
Its a VVC and a trip to rover results in "They all do that mate"![]()
