I'm adding a 7950 to my loop, in the next couple of days. And need some advice on what size rad to use. I already have a monsta 240 in push pull, for my cpu, but am going to add another. So which would be better.A 30cm thick 360mm, or a, 45cm thick 240mm . The monsta is up front, and the 2nd is going up top.
My options are either the NexXxos ST30 triple, or the NexXxos XT45 dual.
