What things will need updated drivers?
Permabanned
26 Nov 2006
guildford, surrey
Just wondering, what things need updated drivers?
All i can think of is GFX card, Motherboard, Soundcard.
Do CPU's, and stuff like Printers need em aswell?
thanks.
from vista open cmd
type "bcdedit /set nointegritychecks on" and
"bcdedit /set oslnointegritychecks on"
to disable driver signing check on every boot.
I did this and then installed all my software i previously had on my xp rig, and it all works a charm so far.
Saying that, i will change to 'proper' vista drivers, but everything works perfectly.
(but generally, yes those are the main drivers i would worry about)
Cpu's no. Printers, possibly. You could always right click\properties\compatibility and select your desired os.
