What to buy? HELP!!!
16 Sep 2018
Hi, Im new to all this but want to buy my first gaming PC, some people are even telling me to build one :S,
i dont care what it is but i have a budget of around £1200 just for the pc. Any suggestions on what to buy? AMD/intel i dont care. as long as it plays well and i dont need to change anything for a while.
please post some suggestions or some builds on what i should buy
Hi welcome
Building your own pc would save you a bit of money over a pre-built. If you don't feel comfortable though you can ask ocuk to build one from a list of parts.
The spec below is a rough idea for your budget. There is some money left over for Windows and also the build fee.
My basket at Overclockers UK:
Total: £1,033.62 (includes shipping: £11.70)
Hey,
What are you looking to play on PC and does the £1200 budget need to include a monitor and peripherals?
There is no reason you wouldn’t be able to try and build your own, for the most part “modern” PC’s are very much just plug-and-play although if you are not comfortable in tackling the potential issues that can arise while building then you might be better served with a pre-built system.
1440p 75hz gaming - console cant match
£40 steam voucher with board, £ free games with AMD card
Total: £1,204.13 (includes shipping: £15.30)​
