What to Choose? Help!
29 Aug 2006
Hi all
Iv just bought a E8400 after hearing about its awsome overclocking potential! After fitting it, it appears iv shorted my mobo....
What board would you guys recommend for my system? Iv got a budget of upto £160 really
System:
E8400
8800GT 512mb
2x 500gb seagates
freezer 7 pro
One of the new P45's. The ASUS P5Q Deluxe is looking to be very good for high FSB clocking.
I'm loving mine.
P45 for sure. Asus are always a safe bet.
Should be targetting at least 4Ghz but depending on the E8400 you get and how much voltage it needs, you might get toward 4.5Ghz.
