So for one reason or another, my system (i7 8700K, Gigabyte z390 UD, 16GB RAM, RTX2060) has what appears to be naff RAM, it's ADATA Premier 2666Mhz with timings along the lines of 19-19-19-43.
System is used mainly for gaming and audio production (Ableton/Cubase).
I therefore have a few options.
1) Buy a couple of Kingston 3333Mhz sticks (or something similar) with better timings for about £90, sell my current RAM, job done.
2) Mess around with the timings/speed of the RAM I do have, assuming it can do a fair bit more that it's currently doing, keeping in mind it's value RAM and doesn't have heat spreaders (which I could buy for a few quid).
3) Forget about it, it's just a bunch of numbers which I wouldn't care about if I hadn't looked into it and I'm happy with my PCs performance. 3333Mhz RAM with tighter timings wouldn't make much real world difference anyway.
I'm guessing there'd be a slight boost mainly in min FPS in certain games but my question is...what would YOU recommend I do?
Also can't see a specific XMP setting for memory in the BIOS, does my motherboard just auto apply XMP settings for RAM? Is RAM just a case of stick it in and press the on button or is a BIOS reset recommended?
Cheers.
Cheers.
