what to do after buying hosting?
6 Oct 2004
England
Hey, so im going to buy some hosting soon to host a site.
Thing is, once ive been to the website,bought the hosting for like £3 per month or whatever it is. What the hell do i do then :o
As ive never done it before im not sure, how do i actually get my website ONTO the internet? I have the html files/css file and images i need.
What exacly do i do :o
You use FTP, File Transfer Protocol, to upload files to the web root, normally www or public_html or htdocs :)
SmartFTP is a great free client and should get you sorted out with connecting to your webspace.
The host name can be whatever - ftp.yourdomain.com or something close to that normally - and the username/password should be supplied by your host after you sign up :)
The hostname is something the FTP program will ask you for when you try and connect. It's just the server address: "which FTP server should I connect to / where is it?" which is of course your domain :)
actually i will buy a reg from somewhere, and then for the time been i will use my free 55mb ntl webspace just to practise on :p
edit: just bought www.nedsurf.co.uk from 123 reg
edit2: for some reason nedsurf.co.uk goes to a page but the one above doesn :confused:
i got a html layout from somewhere on the net. And then edited it that way, i did it like that so i can like see how tis done etc, im going to keep slowly editing it. Then i will try make a design from scratch,but its so much hard trying to do it via notepad than dreamweaver :(
