What to do next?
Caporegime
20 Oct 2004
Just got a bit of overtime money and want to spend a bit of on the car.
Got my new alloys, but not sure to either lower it, eibach springs and blisten shocks.
Get the plastics re-sprayed, there faded compared to the rest of the bodywork and won't polish back up.
Or a new exhaust, not really any need but I just want it.
What would you guys go for?
Im tempted to go for the re-spray as its really bugging.
Forgot to mention, the back bumper also has a slight crack, altough I suppose I could really fix this myself.
Want the shocks and springs so much, but the bodywork is really annoying.
Can't notice when your inside though :p
I concur. Lowering with good quality components is the best modification to make on a car in terms of price.
Which Bilstein's you going for? Blacks or yellows?
Yellows, want the b8s but bit too much.
Possibly the B4s this and eibach springs for about £300.
Will get them fitted for free aswell so would be cheaper than re-spray.
Lower it but don't be half assed about it. Do it properly and do it excessively :)
