- 12 Jun 2008
I'm in the process of making my pc as quiet as possible. Current im using a noctua in push-pull and my GPU is passively cooled, so the machine is quite quiet but still audible.
The obvious solution to me was to move over to watercooling however, consdierng i will eventually upgrade my GPU im stuck between the following options:
Custom loop: i have a dcc 10w res/pump combo from laing (sp?), a cheap rad and a heatkiller 3.0 already from a different build. So i was thiking about using these in my current build to cool cpu and gpu, but will they handle it? i thought the pump might be a bit weedy for the task, and the rad would certainly need changing. The problem would also be fitting the rad in my case (fractal R3)
antec kuhler: for cooling the cpu. good for the job, quiet and self contained. Then use a third party cooler for gpu, with a large slow fan.
What do you guys think? im personally leaning towards the second option, as it will feel more "safe" to me. Which will keep my kit cooler though? (gpu will be 6950)
Cheers
Cheers
