- 18 May 2010
Hi people
So my commute is about to get longer and involve motorway as I have a new job and the radio is really really starting to bug me so I want to be able to listen to MP3's, I currently have this radio broadcasting thing that sits in the lighter socket but for a million and one reasons its frustrating to use and i'd prefer better quality, I was going to replace it with a better version but the quality will only be the same
If my car didnt have the built in sat nav I would just rip the current stereo out and bin it but it does however i've only used it once since I bought the car as I really dont need it I would prefer a standard head unit but I cant be bothered with a cheap nasty rattly fascia that doesnt match and this rather shady sat nav was a laughable £1000 option so it seems a shame to get rid of it
Heres some options, what would you do or what have you done?
1 : Rip it all out and get a new head unit, lose sat nav function and risk a shady fascia, attempt to sell NAV for what will realistically be peanuts or keep it and refit it when I come to sell the car (CBA) I can have a bash at fitting this theres a decent guide on Fitaudio (great site)
2 : Get an X-Car link and upgrade the speakers and hope it sounds good enough, this retains the OEM look and keeps the sat nav but i'll maybe have to find a local fitter as fitment is a little more complicated, where does the unit go, etc?
3 : Leave it as is, its really not worth the hassle
I'll probably need to find a fitter anyway as I want upgraded speakers and i'm one of those that would rather pay someone else to a good job and then take it back with any problems however finding a good fitter is a challenge in itself, i've had some really bad experiance with car audio fitters! Anyone know any good ones in Manchester area?
Thanks
Thanks
