What to do with no use parts.
27 Oct 2012
Hi all, so basically I got given a p.c where everything is to old to do anything with. What do you guys advise me doing?
I have
Intel i5 750 o.c at 4ghz.
Gtx 960 2gb (selling on ebay)
H65 corsair cpu cooler
Stealth x tream 2
P7p55d-e motherboard.
They are just all so old I can't sell them. Should I take them to the tip? Local computer store ?
I have
Stealth x tream 2
I'm pretty sure the motherboard will fetch £50 on the bay.
Find a charity, there's going to someone out there that can't afford a PC and could make use of it. It would be a shame to just throw working hardware away.
A lot of small charities depend on these donations. It may be old to you, but if they're on something from the xp era, it's a huge upgrade.
Thanks will look into tjis
Thanks will look into this when this covid has gone. As all my local ones do not accept anything at the moment so something for thought. Thanks!
Failing that if you do end up throwing it away make sure it goes to a proper recycling centre and not just in the bin.
