nbkpsycho said:Well i got rid of it because it wasnt good enought tbh. It wasnt doin its job @ 1680 by 1050. 320mb just didnt cut it. I also was thinking of getting the 2900XT depending on its price or 2nd hand 8800 640 GTS or GTX.
Duff-Man said:The 640mb GTS won't give you much over the card you just sold. Only in certain parts of certain games will you see the benefit (where the texture cache exceeds 320Mb you won't get the system mem to video mem paging any longer, but the raw FPS won't change at all).
Your only real options then are the 8800GTX or the 2900XT. Given the situation, you should at least wait until the 15th to see for sure what the XT can do. The rumours and leaked scores suggest it will perform similar to the GTX though.
