Right now u can see in my sig that my CPU is old and i want to upgrade quick!
but i dont know wat to go for..
do i go with the simple option of just plugging in a Phenom II 940 BE which is the best CPU my mobo can take.
Or do i go intel get a second hand Q6600/E8400 which will need a new mobo for which i can decide between the Foxconn BlackOps (X48) or Asus P5Q deluxe (P45)? difference?
as i want to upgrade for around 200 quid. Or is there anything coming out soon cheap enough for this. I am going to get more RAM regardless of the option so that doesnt need to be in the budget.
any help will be appriciated my x2 just doesnt cut it anymore!
thanks
thanks
your right... its not.. how odd!
