What to get - external hard drive solution
18 Oct 2002
Maidenhead
Hi all,
Sitaution:
I have a desktop and a laptop. I only have a 100mb network.
I want to share movies between the network (dell dimension 9200) and the laptop (dell d630)
Desktop only has internal sata ports or USB 2. Laptop only has express card or firewire or usb.
I have a few options as I see it.
1) Get an internal drive and upgrade to a gigabit switch
2) Get a sata to estata faceplate like this
And a drive with esata and firewire like this
and use firewire to my laptop
3) Get an internal drive with a caddy like this
and get a sata to estata faceplate like this
and use usb2 to my laptop
Whats my best bet? Will be playing 720p movies.
A wired 100mb network connection should be able to handle 720p.
If it won't then a Gigabit card for the desktop and a small Gigabit swich wouldn't cost much. The Laptop should already have built in Gigabit.
If you decide to go with an external drive be aware that the faceplates you're linking to aren't eSATA, they just present normal SATA data and power connections externally.
I assume you are aware that an external drive can only be connected to one machine at a time? Your post seems to suggest that both may connected at the same time.
One option you haven't listed is adding eSATA to the laptop using an express card.
Thanks for your reply. Yeah I know they wont be able to be connected to both at the same time unless I go NAS.
Ahh didnt know they were just normal sata connections. Does it matter? If I get an external drive with esata, I could just get a sata to esata cable couldnt I?
Are the esata express cards good?
100Mbit can easilly play 1080p. You could quite easilly have two or even three computers streaming 1080p from your desktop.
I would get another internal drive. If you dont want want to leave your PC on all the time then I would go for an external drive (USB for ease of use between your desktop and laptop). Just read your above post, why do you want to use esata on your laptop? 30-35MB/s isn't too bad (USB), just do all your copying from your desktop's sata -> esata adapter.
